Relative Humidity
Relative Humidity
Relative Humidity
I have a recent situation where in, we were task control the relative humidity at 50%-55% of the cooling tunnel at the 17 deg.C. The cooling tunnel does not have any dehumidifier to control and eliminate the present of moisture in the air. Do you have any recommendation or technology aside for the dehumidifier on how could attained the required RH at the given temperatue with out investing too much on the Dehumidifier.
RE: Relative Humidity
That gives you a dew point of 43.72 to 46.23F and is difficult to maintain without a dehumidifier. You can try with a DX coil if the supplier guarantees. IMHO, go with a dehumidifier.
Thanks quark, your input is very much appreciated.
