Glycol content in Cooling system
I would like to know what is the effect of over dose and under dose of glycol in the cooling system.Is there any effect if the existing glycol will be mixed with different gycol such as frost gycol.
RE: Glycol content in Cooling system
Dave
h
I agree to 50% is ideal for freeze protection. Unless the pipes are actually being designed to work outside we usually specify a 30-35% concentration as this will provide 'burst' protection down to -36F or so.
60/40 is the max we have ever used in Arctic applications.
Mixing glycols may or may not be a problem. It is best not to do it.
Rust never sleeps
Neither should your protection
http://www.trent-tube.com/contact/Tech_Assist.cfm
