Nylon growth in water
3
I'm thinking of using a nylon or Nylatron GS roller chain & sprockets in an application which may see a lot of water - possibly even immersion for days at a time.  Room temperature.  Very low loads and speeds.  I know nylon is hygroscopic, but I don't know what to expect in terms of percent dimensional growth.  Anybody know the answer or where to look it up?
RE: Nylon growth in water
3
Hi Philrock,
You might want to try Delrin or Acetal instead of Nylon, it has a high tensile strength, good chemical resistance and wear properties, and it absorbs less water & swells less than nylon does. Here is a link to some information about using plastics under water...
http://www.quadrantepp.com/source/acetals.html
Nylon 12 supposed to have the lowest moisture absorption, Here is an in depth report in PDF regarding nylon 6/6 and 12...
http://www.rmb.com/about_rmb/Data_Sheets/Nylon_12_Comparison.pdf
Here's a design guide...
http://www.riversidepolymers.com/designguide.pdf
http://www.riversidepolymers.com/moldingguide.pdf
http://www.wellmaninc.com/Wellman/ermolding/molding%20guide%202.pdf
Here's an html page with a chart on mechanical properties and water absorption of nylons
http://www.machinedesign.com/BDE/materials/bdemat2/bdemat2_29.html
Sometimes it's possible to submerge nylon under water for 48 hours prior to machining, to account for dimensional changes due to water contact when the part is in use.
As an experiment, I put a 6/6 nylon washer .031" thick X .475" OD X .190" ID in a glass of water for several months. The Thickness hardly changed at all, measuring with dial calipers I think the increase in thickness was about .0008".
With plastics, I think the swelling is proportional to the size of the part. A fairly small part might not change that much, where a larger part would, with the same percentage moisture absorption.
I know www.wmberg.com has roller chain and sprockets, along with www.sdp-si.com/. You might also try www.nordex.com & www.pic-design.com/.
http://www.qtcgears.com/ has a technical reference on  gears, the plastic gear section has a chart that list moisture absorption and properties for different plastics.
Hope this might have helped.
John
John2004,
This is a tremendous help - thanks a million!
philrock
