Plit Window Sheets
Plit Window Sheets
Plit Window Sheets
Anyone,
 Is it possible when you have multiple sheet drawings to view the sheets in tiled or split window??
RE: Plit Window Sheets
No I don't think that is possible... you don't get the SPlit option in a drawing like you do with a part or an assembly.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
If you want to view multiple sheets/parts/assemblies, then Window > Cascade, Tile, etc.
Flores
SW 2006 SP1.0
Thank You Scott. I did not think it was possible, but wanted to verify.
You can open a single file in multiple windows.  With your drawing open, click menu "Window --> New Window".  Now your file is open in two separate windows, and you can view multiple sheets.
I could be the world's greatest underachiever, if I could just learn to apply myself.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
