Suggest fabricator for rectangular crush tubes
Hi all.
We are trying to assist a client in pricing some crush tubes for a damaged railcar.
The tubes to replace are described as follows:
80 x 80 x 5mm  sq. tube with 5 mm inward indentation in 2 webs at mid-span (approx. length 900mm)
250mm round tube x 5 m thick with an outward bulge of 5 mm at mid-span ( approx.length 500mm)
Can anyone suggest a fabricator (preferably Canada or US) capable of this, for small quantities (say 20 of each)?
Thank you in advance.
tg
RE: Suggest fabricator for rectangular crush tubes
Try Boyce Industries in Illinois - not sure if they do rail parts but they do short run tube fabrications
"If A equals success, then the formula is: A = X + Y + Z, X is work. Y is play. Z is keep your mouth shut."
-- by Albert Einstein
