silicon steel specific heat
hi
i need to know exactly the specific heat of silicon steel used in building the transformer cores.
is it same as the (iron/steel) specific heat that is ( 452 J/Kg/K )
thank you
RE: silicon steel specific heat
The typical value of specific heat for Silicon Steel is: Cp=600 J/kg • K
Just out of curiosity:
Will it be the same for the steels manufactured in different processes?
hot-rolled steel
grain-oriented steel
high-permeability steel
domain-refined steel
All are/was used in transformer cores.
Failure seldom stops us, it is the fear for failure that stops us - Jack Lemmon
Make the best use of Eng-Tips.com
Read the Site Policies at FAQ731-376
Hi Ralph
In general, the specific heat are different for different alloys.  Typical values are as follow:
    - Cold rolled steel:        Cp= 481 J/kg.K
    - Grain-oriented steel:   Cp=812 J/kg•K
    - High-permeability:      Cp= 460 J/kg.K
Dear cukt2000
could you please give me a link to read more about this topic?
