Centaur Turbine flue gas uses
I was hoping to get a little feedback from anyone making use of the wonderfully hot and plentiful exhaust of a gas turbine. It's located in my gas plant here in S. ALberta Canada, and is a Centaur Type H driving a gas compressor. The exhaust is:
Heat Rate - 12,905 Kj./KW-Hr
Flow - 68,180 Kg/Hr.
Temp - 445 deg.C
It sure seems like a waste, so I'm starting to bounce some ideas around. This unit runs 24/7 with the exception of maintenence and failures.
Brad
Temp - 445 deg.C
Brad
RE: Centaur Turbine flue gas uses
There are waste heat recovery systems available out there. It is a matter of finding manufacturer's/suppliers. You may want to do a web search.
Dave
Let us know what you decide.
They make small once-through steam gnerators (OSTG) for this type application. I think they have a number of Canadian installations.
