Want assembly with only some parts shaded w edges ?
have an assembly displayed in Shaded with edges mode.
I'd like SOME parts to be shaded WITHOUT edges.
I seem to be able to do one or the other.
How do you do a combo of both display types in one assembly?
RE: Want assembly with only some parts shaded w edges ?
It's either all or nothing. You can't have some with edges and other without - ER.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
2006 Display States may allow this now.
Jason
UG NX2.02.2 on Win2000 SP3
SolidWorks 2005 SP5.0 on WinXP SP2
SolidWorks 2006 SP0.0 on WinXP SP2
SW2006 Display States can definitely show Shaded with edges & Wireframe simultaneously ... not sure about the others though.
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions  FAQ559-1091
Ahhh good point... forgot about the Display states. Then I have to retract my first answer, because I just tested this and it does allow you to change between the different states per part.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
SW2006:  Right-click the part or assembly in the tree > Component Display.  Mix and match as you please.
Flores
SW 2006 SP1.0
Work place has not decided to make jump to 2006 yet so for now I'm stuck with 2005.
Is there any way with 2005 to at least vary the edge colors per part within an assembly.   If I could make the edges on some parts not-black while leaving others black, that might be good enough for me.
Possible?
What's wrong with just colouring the parts?
Maybe if you explain what you are actually trying to achieve, we may be able to offer a solution.
