Help on Ansys acoustic analysis
Hi Everyone,
I'm trying to run some acoustic cases on Ansys using the element FLUID29. I'm having trouble to extract the velocity nodal result in a fluid element after running a harmonic analysis. It seems that only nodal results for pressure are avaliable, although the specs of this element (FLUID29) say that the nodal results for displacement are avaliable. Up to now I can only extract displacement (or velocities) in the fluid structure interface but not on a fluid element itself which is limited to pressure results.
I would greatly appreciate if someone could give me some ligth on this topic.
Thanks in advance.
Thanks in advance.
