Fastener... HELP!!! Press Bolt
I am in need of a fastener information and companies - I am a design engineer looking for a -
"Prees bolt" - Manufacture and catalog
"Clinch Bolt" - Manufacture and catalog
"Knurled Bolt" - "wheel stud" Manufacture and catalog
about 3/8 or 10mm in dia 1 to 2 inches in length.
Basically a good quality "wheel stud". I do not need certified hardware as we are a race car engineering service. The hardware must be off the shelf stuff you know like AN hardware. I have tried the internet and even calling Rosan - Rexnornd - But the companies are to big and hard to get a hold of a person that knows what I am talking about.
Thanks in Advance
AZ
Thanks in Advance
AZ
RE: Fastener... HELP!!! Press Bolt
You posted to an Aircraft thread, was that what you had intended? There is a group "Welding, Bonding & Fastener engineering" that might be more appropriate but there are others.
I put Rosan Rexnord into Google and several ditributors showed up, depending on who you talk to there, some of those guys are almost as knowledgable as the manufactures.
But, to answer your question why not look at www.thomasregister.com some guys like globalspec.com and there is a fastener manufacture fastenal.com and then the old stand by mcmaster.com.
Good luck
_______________________________________
Feeling frisky.........
www.tailofthedragon.com
wheel studs (1/2" or 12mm):
http://ww
http://st
