SW and MS LiveMeeting
We use LiveMeeting for web conferencing.  I have found that SW wreaks havoc with the LiveMeeting screen sharing.  Edrawings seems to work fine, but SW has all sorts of issues with screens not refreshing properly.
Anyone else have experience to share using LiveMeeting and SW?
RE: SW and MS LiveMeeting
Have you looked at WEbex or some other type of web conferencing tool. I know Webex works fine with SW.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I've used Webex, and it works great.  I'm locked into LiveMeeting due to company policy.
  I have tried it a couple times. We work over the network thru servers which makes LM work veerrry slow and SW does not come in clear. It is more effeciant for me to get everyone in a room or 1 on 1. We have Webex, but only the IT dept is allowed to use it.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
I have heard that the problem is caused by the method used to handle the OpenGL graphics data. Some programs just handle it better than others.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
You should try software opengl, as solidworks uses overlays for the viewport. Most programs that capture / blend / etc the display output don't work well with overlays.
For instance I have to use software opengl when running 'glass2k' to make SW transparant to trace photographs of hard to measure shapes.
Stefan Hamminga
Mesken BV
2005 Certified SolidWorks Professional
Mechanical designer/AI student
