Changing Part Number/Move files
I currently have an assembly of approx 1000 parts, which consist's of many sub assemblies. I want to be able to change the part numbers and move the parts to a different directory structure with out loosing or having to recreate my assemblies. Is this possible in Solid Edge Ver16. I am able to do it in SolidWorks but havent found an effiecient way of doing it in Solid Edge, can anyone help.
RE: Changing Part Number/Move files
To move the files, use Revision Manager. You'll find Replace function (Ctrl + R) useful to eliminate repetitive typing.
Regards.
In what way do you find the sequential number easier in the assembly?
If you change the filename, use 'Where Used' function to track and update other assemblies that share the same file.
