Minimum wall thickness when machining Delrin and PC.
What should the minimum wall thickness of Delrin and PC be when machining.  Thanks
RE: Minimum wall thickness when machining Delrin and PC.
Your minimum wallstock really depends on your machining process.  If you machine one side, then cast it into a "holder", you should easily be able to machine down to at least 1mm (.04").
