Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I just wanted to say THANKS for the forum. The knowledge I gain from your site is invaluable..."
Geography
atomicman (Structural)
20 Nov 01 14:38
I have a curved bridge in plan (X-Z plane, Y is vertical)with intermediate piers perpendicular to the curve.  BETA angles are used to correctly rotate the columns into proper local coordinate system (local Z is perpendicular to curve).
I need to get top of column displacement along the pier (in the local column coordinate system) instead of the typical global displacement for response spectra analysis.  Does anyone have a solution to this?
One alternative would be to use the command MOVE OBJECT to rotate the column to global coordinates.  The downside to this solution would be changing BETA angles and the EQ direction for each run and re-running GT-STRUDL for each pier.
Any advice is appreciated.
TSM
jonhren (Structural)
10 Mar 04 10:18
LIST SECTION DISPLACEMENT LOCAL MEMBERS "X"
this should work, however it only gives for displacements and not rotations.
Close Box
Join Eng-Tips® Today!
Join Us             Close
