GE IAC relay as Directional Overcurrent Relay?
I'm looking at some one-lines for an old facility that shows several GE IAC relays used as directional overcurrent relays. Since the IAC is non-directional, I'm not quite sure how this is accomplished. I don't doubt the drawing is correct, but I'm curious about the implementation.
Maybe some type of external polarizing relay to block the trip contacts?
Has anyone run across this before?
RE: GE IAC relay as Directional Overcurrent Relay?
The relay is listed as an IAC51A1CAP, so I'm guessing the "CAP" is making it directional somehow, but I can't find any GE info on a CAP relay or function.
The one-lines do show connections from the PTs to the relay, so maybe it was some special add-on element.
Can you go to the installation and look at the relay(s) in person?
You're right - there were a lot of "special" relays made back in the old days.
Thanks.
dpc:
For IAC-overcurrent relays:
http://ww
For CAP-relays:
http:
(pg 15)
Failure seldom stops us, it is the fear for failure that stops us - Jack Lemmon
Make the best use of Eng-Tips.com
Read the Site Policies at FAQ731-376
