drilling a .096 dia into 316 x 3 inch/ not going straight
I'm trying to drill (in a lathe)a .096 dia into 316 stainless X 3 inches long. I'm having problems with it staying in the center. I would like no more than .010 TIR. Any ideas out their ?
RE: drilling a .096 dia into 316 x 3 inch/ not going straight
Even with all this I would say you are up against it, could you outsource to a specialist deep drilling company? Failing that drill the hole with sacrificial ends true up between centres.
Good luck.
One trick to improve straightness is to turn the part and the tool.
