10,000 gal. 98% Sulfuric Acid Tank Carbon Steel material
We are planning to replaced an existing 10,000 gal. 98% Sulfuric Acid Tank Carbon Steel material, 3/8" thichness wall, 18"-0" T/T x 9"-0" diam., built in 1975 (our location is at Carolina, Puerto Rico Lilly site Pharmaceutical Plant). It is an atmospheric tank w/ dish heads.
I will like to know if Ul-142 Code w/flat heads and using a corrosion allowance of +1/8" = 1/2"wall thickness is the best alternative vs. API-650 w/flat heads and 3/8"wall thickness or do we have to stay with the original design of dish heads.
RE: 10,000 gal. 98% Sulfuric Acid Tank Carbon Steel material
Steve Braune
Tank Industry Consultants
www.tankindustry.com
