use of shunt-trip breaker for service entrance
Any problems with this? The design calls for a Square-D LAL36400 400A breaker, The same breaker with shunt trip is available new for a lot less from an NOS supplier. I imagine the shunt circuit can just be ignored and it will function identical to the regular breaker?
RE: use of shunt-trip breaker for service entrance
I can't see why that would be a problem.
What is your concern?
Failure seldom stops us, it is the fear for failure that stops us - Jack Lemmon
Make the best use of Eng-Tips.com
Read the Site Policies at FAQ731-376
So the Square-D breaker with shunt trip is cheaper than the Square-D breaker without shunt trip ?
Surely not.  Sounds like you are getting a bargain.
What does NOS mean ?
"New Old Stock".  Usually refers to stuff that
has be superceded by a later version, or just
possibly that it has been on a shelf for years. :)
Almost always un-used, generally still in the box.
<als>
The shunt trip should not be of any concern.
