Intellipoint Problem + Solidworks 2006
Hi all,
I just upgraded to SW2006 and I am having trouble with using the Microsoft Intellimouse software.
It makes the wheel work in such a way that once you are zoomed in so that the scroll bars appear on the window, the click+dragging with the wheel does not rotate the model, but it scrolls up and down.
Has anyone come across this problem?
I can disable Intellipoint, but I use the other buttons for shortcut keys so I would like to keep those if possible.
RE: Intellipoint Problem + Solidworks 2006
Updating Intellipoint software solved the problem.   (Just choose "middle-click" as the option and viola)
