Tension Only Member for Bracing
I am a relatively new user to ETABS. I am trying to define bracing as Tension only. I set compression limit to 0 but i still see axial compression when i analzye the memeber. What am i doing wrong?
RE: Tension Only Member for Bracing
I have done all of the steps you listed but when i go to view the LINK FORCES it is not an option. What do you think is wrong?
Also, i guess ETABS does not design these members, correct?
2. Nope - but if you can't design a tension member based on an axial force you are SOL =).
