Prevent Corrosion
Prevent Corrosion
Does anyone think that it would work to attach bonded sacrificial anodes to a car to prevent body rust?
RE: Prevent Corrosion
http://www.corrosion-doctors.org/Car/Frames.htm
For the sacrficial anode to work, you need ELECTRICAL connection between your anode and the part you're protecting. (Don't mount it to underbody PVC!)
Also, be mindful of whatever you use to strap it on. If it's metal, it will also corrode! Some plastics don't hold up well to temperature changes.
The most common sacrificial anode used in the automotive industry is zinc (hot dipped, zinc plating, galvaneel, etc.
Be careful not to create any crevice corrosion cells.
In the end, I think you might have a fun project, but I think you'll be disappointed if you do a Cost/Benefit analysis.
