SAE J2340 550X
SAE J2340 550X
SAE J2340 550X
Where does one find a simple and free listing of chemical makeup and mechanical properties of some steels? I am specifically seeking SAE J2340 550X.
RE: SAE J2340 550X
Thanks but I have reviewed that document and found the information lacking of chemical make up. Also, the Mpa is 586 when in fact I have been told it’s actually 550 thus the 550 designation. I was hoping to find a mill or supplier that had all the information readily available to look up for those who may purchase.
RE: SAE J2340 550X
kbtonkin,
First, the minimum yield strength requirement for grade 550X is 550 MPa, as stated in Table 4 of SAE J2340.  I am not sure where you see the number 586.
Second, the reason there is a limited requirement for chemical composition is because this standard was specifically created to define performance criteria (strength, elongation) instead of tightly controlled chemical composition limits.  These HSLA grades typically have C contents of ~ 0.06-0.10, Mn of ~ 1.00-1.5, and small additions of V, Nb, or Ti (around 0.05-0.10).  All number are in mass percent.
Third, you can find more information from suppliers like US Steel, ISG, AK Steel, etc.  Most of the steel suppliers reference ASTM standards like A 1011, but the products are essentially the same.
