Sending documents to the printer
I am trying to find a way to send an image file to my printer when its name appears in a cell in an Excel spreadsheet.
I would like to avoid inserting the image into the spreadsheet and then printing it.
Any help or suggestions are appreciated.
I would also appreciate help with keywords to search the help files for.
RE: Sending documents to the printer
You have file name stored in Excel, you can activate the computers imaging software (Paint if .BMP) then you can call Paint's print function from VB.
Check out www.freevbcode.com for downloadable examples.
Thanks, I have also added the Microsoft Office Document Imaging (MODI) library to my VBA editor.
My skills with VBA are primarily focused on Excel so I would still appreciate any input using other applications.
IrfanView is a freeware image viewer with command line capabilities.  You could build a command line string to print the file through IrfanView and run the string with a wsh.shell object.
