insulation visual inspection
which points do we have to take into account during visual inspection of insulation?(other than experimental results)
RE: insulation visual inspection
Electrical insulation?
Acoustic insulation?
Some other type of insulation?
Why are you performing the inspection? Do you suspect a problem? Are you having problems and want to avoid more? Is this part of an overhaul, or replace as needed?
Are you inspecting 100%, or sampling?
Well posed questions get more replies.
we are trying to know if we can use some of our thermal insulation which remain from one of our project which is finished six years ago. we are a boiler manufacturer company which use thermal insulation in casing and duct panels of hrsg(heat recovery steam generator).
