typical air fuel ratios of diesel engines
Hi all!
Can anyone tell me where I can get a range of typical air-fuel ratios for diesel engines?
Thank you!
RE: typical air fuel ratios of diesel engines
This thread was recently discussed in lengthy detail, drill down a bit.
Franz
i didnt quite get that... what was the title of that thread?
something like "ideal air fuel ratio for a diesel"
Due to limitations of injection hardware and other thermo stuff 70:1 is bout the bottom most engines see.  Theroetically af ratio can go infinitely lean if enough heat is available.
