V22 Tilt Rotor
V22 Tilt Rotor
Has there been any recent developments in the V22 Tilt Rotor vehicle? Is it being mass produced, ect...
RE: V22 Tilt Rotor
RE: V22 Tilt Rotor
The ship is in Low Rate Initial Production and is currently completing operational evaluation with the Marine Corps and Air Force, after being returned to flight status. The CV-22B Air Force Special Ops Osprey was recently rolled out, but hasn't flown yet.
RE: V22 Tilt Rotor
It is still to early to speculate on the cause of the latest accident
RE: V22 Tilt Rotor
VRS is NOT COMMON to ALL helicopters and tiltrotors. This
appears to be a marketing ploy. Helicopters, which have lighter disk loading usually settle with power and can readily be controlled to either exit the situation or make a controlled landing. A tiltrotor which has much stiffer blades (props) also begins to settle with power , however it can each a state where severe flow changes result in vortex near mid span, produce abrubt and sometimes violent vibrations and loss of control ( rapid pitch down and roll to inversion) -- and CRASH BIG difference!!!
