Reducing TDS without RO
Is there any method apart from RO by which the TDS could be reduced? For example I have got a well containing 7000ppm TDS and 2000ppm Total Hardness. I would like to utilise this well for industrial purpose for this the TDS should be below 2000ppm and the total hardness <1000ppm. Kindly suggest any method by which TDS could be reduced.
RE: Reducing TDS without RO
You may also consider Electrodialysis (ED).
It is unlikely that any precipitation process by itself is feasible. Most of the salts are probably as chloride and the precipitation process will have no effect on the chloride ion.
