Create solids from faces?
Hi everybody, is there a way to create solids from closed polyface meshes?
When I import objects from VIZ, from a simple box to a human body, it comes as a polyface mesh and I would need to have it as a solid.
Does anyone know how to do it?
thank you
regards
thank you
regards
RE: Create solids from faces?
The lisp file has this explanation:
M2S (Mesh-to-Solid)
;; Creates an ACIS solid from an open 3d polygon mesh.
;; Take 2 - Updated 7/7/1998
;; - Works with REVSURF'd meshes that touch or cross axis of revolution.
;; - Works even if solid being constructed is not fully visible on screen.
;; - Works with all open meshes created with REVSURF, RULESURF,
;; EDGESURF, TABSURF, AI_MESH, and 3DMESH. Most of the stock 3D
;; surfaces will work if you use DDMODIFY to open them in the M
;; and N directions.
;; - Does not work with polyface entities.
;; (c) Copyright 1998 Bill Gilliss.
;; All rights reserved... such as they are.
