Slim line fan coil needed
I got a problem with very little ceiling space for a 4-pipe fan coil units to serve a corridior.
7" total ceiling space for ceiling mounted units .... similar to EMI CAF4-08 ....... EMI's are 9+"
Will take a wall mounted (up high) near the ceiling ..... something slimline w/ integral condensate pump.
I don't have room for an air system.
RE: Slim line fan coil needed
Trane has some fan coil units that you could use- I think the type is Slim Line HFO.
www.trane.com
I have no room for ductwork
Sounds like you may have to go to a refrigerant based system like Mitsubishi CITY Multi units (heat pumps).
http://www.mehvac.com/Products/technology.asp?TechnologyID=628295
Perhaps if you're desparate and have room locate the Condensing unit in a location that can be heated/cooled by your hydronic system.
Consider console type unit located in room of consider horizontal unit installed in toilet room that can have lower ceiling & fan coil discharged ti adjacent corridor.
This is an old hospital circa 1915 ..... corridor is non-patient ....... there is a slew of electrical conduits/steam/pumped condensate lines above the ceiling.
The ceiling height is 7'-0".
The walls are 12" thick concrete.
They don't build them like this today.
Try a company called Multi-Aqua. I Believe they have some wall mounted units.
