Pump Station: Center of Gravity?
I am trying to find more information on calculating the center of gravity of the water packaged pumping system.
Is there any software in the market place of USA to get it approximately info on the center of gravity of the pump station?
Thank you in advance!
RE: Pump Station: Center of Gravity?
Check w/ pump vendor - they should have most of it.
"If A equals success, then the formula is: A = X + Y + Z, X is work. Y is play. Z is keep your mouth shut."
-- by Albert Einstein
Thank you SprintCar for an advice!
But, I am looking at the system with more components then just a CC/ES pump. There are the other items such as the electrical pump motor and control panel, suction and discharge headers, piping/branches with the PRV's, skid,...
Do you have any additional suggestions?
Thanks!
any reputable packager of the equipment, i.e. the company that builds the skid buying the indididual items from the different oem, should supply that information as part of the operation and service manual.
saludos.
a.
