sewage treatment plant structural design
I'm in the process of designing a sewage treatment plant(STP); I'm following the ACI for environmental structures. I tried to look for some other references that provide a guidelines and precautions in the designing process or books that provides some examples, can any one provide some help or gaudiness on the design process.
The STP is to serve an indsrial area which will be built on the ground surface, i.e. the critical design case will be when the tanks are full. moreover, the walls are 4.5m high.
RE: sewage treatment plant structural design
