Pattern driven by a table?
Is it possible to create a pattern in one direction with individual spacing (first spacing 20mm second 30 mm etc) and variable number of instances which are driven by a table (like table pattern in ProE)?
/Akesson
/Akesson
RE: Pattern driven by a table?
Use then "user pattern" to instanciate your geometry
I've already tried that way but as I see it I can't drive the number of instances with a parameter. The only way I see is to add/delete points in my sketch.
The method you describe should work if you're can activate/deactivate a point in the sketch but I hav'nt been able to do that.
/Akesson
Not able to choose points in a sketch...
Thanks for your ideas.
/Akesson
I've tried the porjection idea and ended up with the same problem as you. The problem is that I would like to use the pattern as reuse pattern in the assy so I can't have too many points in the sketch.
/Akesson
Not the easiest way to do it but I'll try it.
/Akesson
