Linear sliding bearing material
Hi all,
  I am looking for a plastic material for linear sliding bearing application that will see high PVs, need a low co-efficient of friction, see a max service temp of about 325 F and see oil mist constantly.
Thanks in advance,
Brother John
RE: Linear sliding bearing material
325 deg. F. That's about 163 deg. C. www.maritexbearings.com may be able to help.
Here is one of many suppliers of sleeve bearings of all sorts.  We used this a lot in our manufacturing function.
http://igus.bdol.com/iglide.asp
check out GRAFLON  (= graphite filled teflon)
Thanks for taking the time to respond.
Brother John
