Pattern Language for drawings
Is anyone aware of a "pattern language" for drawings? I am trying to define the characteristics of a quality drawing. Here are some things I've come up with so far:
Drawing/Design Pattern Language:
-Clear and unambiguous
-Completely defines part/assembly
-Drawn for ease of part inspection
-Mistake proofed (poka yoke)
-View and section relationships defined
-Adequate white space
Please share your thoughts.
Don
Don
RE: Pattern Language for drawings
If this is for CAD, look into establishing drawing templates that are controlled and everyone uses.
I see a conflict with "completely defines part" and "ease of part inspection". Drawings for fabrication can be incredibly different from inspection drawings.
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Sometimes one drawing does not do it all. At my last job, it was often necessary to develop a separate "process drawing" for checking parts. One could not build a tool from these prints, however.
ewh has a good point about standards. Being literate w.r.t. a specific standard (ASME, ISO) should eliminate the need for "over-explaining". For that matter, there already is a "pattern language" in GD&T which is detailed in ISO and ASME standards. Learn it, and you will likely lose the need to invent something else.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
