Pressure Relief Valves in Buried Tank
I have a partially buried tank that needs to have the size and number of pressure relief valves specified. Does anyone know the procedure for making this determination? I notice that the manufacturers do not seem to be calling out anything on their cut sheets. Thanks in advance for any input.
RE: Pressure Relief Valves in Buried Tank
If anyone has any other suggestions, feel free to contribute. They're probably just as valid.
Assume or find a maximum rainfall rate. Assume the rainwater goes into the ground. Assume or determine the amount of void space that can be filled. That should give you the maximum rate of rise of the ground water, and assume the water inside the tank must be filled at the same rate. That gives you a flow rate of water into the tank. Determine the maximum differential water pressure you can have in the tank shell or tank floor. That gives you the driving pressure for that flow rate. Then it's a matter of sizing flow in the ground and piping for thos conditions.
