Repeat Region
Repeat Region
Hi All,
I have a problem with my repeat region. I want to fix the Indexes of the parts, but I have to skip some of the numbers in table. Note, this is our procedure if you remove a part and add another part it becomes the next number in the repeat region. Back to my problem, I have part (foam tape) that is family tabled to different lengths, and is assembled into the same assembly, I can not fix this part in the repeat region and it drop to the lowest skipped number in my table. Is there a tip or work around to get this item at the correct item number in my table??
Tofflemire
Tofflemire
RE: Repeat Region
I seemed to have fixed my problem, but I do not know what I done. I was playing with the filters, attributes and recursive functions. I now able to fix that part in the right item order I needed it.
Tofflemire
