filament wound structures layer thickness and fiber angle accuracy
In filament wound structures such as pressure vessels what is the accuracy of layers thickness and fiber angles.for example can we say alayer is 1.1 mm thick and the fiber angle is 9.1 degrree or can we be more accurate like 1.11 and 9.12.
Cheers
alleak
RE: filament wound structures layer thickness and fiber angle accuracy
Fiber angles are probably held to no more than +/-0.25° in the barrel section and +/-2° in the end domes.  Ply thickness will be a function of how tight the resin content is held on the prepreg or wet winding process.  The tolerance on cured ply thickness of prepreg materials (nominal thickness ~ 0.008 unch) is typically not less than +/-0.0001 inch (+/-0.0025 mm)
Hi SWComposites ;
Is there any refrence for your answer.Is there any website.
Cheers
alleak
Info is based on my experience.  I doubt you will find specific info on the web.  You might try the following book on filamant winding:  "Filament Winding Composite Structure Fabrication" http://composite.about.com/library/products/aafpr020828.htm
Why do you want to know about angle and thickness tolerances?
In an optimization procedure angle and thickness are design variables and i want to know how accurate should i be.
Cheers
alleak
In that case you should ask the manufacturing engineers who will be responsible for fabricating the structure what tolerances they can acheive with the specific winding process.
