sketch replace or feature reroute
I have a basic sketch (a line and a tangent arc) that is pretty early in the model. I use it to define many things in my part (top profile, float lines, sweep paths, etc).
Well, afer the model was build, the ID person decided that it should be a line and a tangent spline instead.
Is there an easy was to replace that arc with a spline? If I do it the hard way (and bypass the warnings I get), I've got to re-edit all these features and recreate sketches or guide curves to reference the spline.
Conversely, could I take these failed features and tell them to reference the spline instead of arc (and not have to manually redefine them wit the spline).
Cheers,
An
Cheers,
An
RE: sketch replace or feature reroute
Or is it the ID guys intent to vary the shape of the spline?
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions FAQ559-1091
Create a sketch to replace the original, right before the original sketch in the feature tree. Identify features referenced by the original sketch using Parent/Child. Go through each feature, and replace references to point to the new sketch.
I call this "neurosurgery". Actually, it's closer to replacing DNA. It an be done, but there are no shortcuts; just mindful patience.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
i'm surprised solidworks hasn't addressed this (pro/e has a replace feature that lets you preemptively redirect whatever referenced an obsolete sketch entity to a new one). This has to happen more often in solidworks, since you can't reverse sketch offset entities or make then coincident with the original line once they're made.
