USING DLOAD in ABAQUS
I need to specify surface load which is non standard. I am using the user-defined load option but it gives the error that usersubroutine DLOAD not found. Where do I  put the subroutine . I tried putting  it in the same directory as the job file but didn't work. I added it at the end of the .inp file and it still gave the same error. Please tell me what I should do.
thanks,
Manoj
RE: USING DLOAD in ABAQUS
Read the manuals !
Example command to run using DLOAD subroutine in file "mydload.f":
abaqus j=job1 user=mydload.f
thanks! using the command did help me move forward but now it gives the error df.exe not found. I am using Force2 compiler for FORTRAN which is a free software. What should do?
I have installed Intel Fortran 9. Abaqus gives the following error now. Does any one know why?
thanks
df: warning: The Intel Fortran driver is now named ifort.  You can suppress this message with '-quiet'
End Compiling ABAQUS/Standard User Subroutines
10/20/2005 11:04:46 PM
Begin Linking ABAQUS/Standard User Subroutines
CVTRES : fatal error CVT1107: D:\VC98\lib\oldnames.lib is corrupt
D:\VC98\lib\oldnames.lib : fatal error LNK1123: failure during conversion to COFF: file invalid or corrupt
ABAQUS Error: Problem during linking - ABAQUS/Standard User Subroutines
ABAQUS/Analysis exited with errors
Manoj,
I can't help you there. The linker is finding trouble with the library (which I think is C++). Try asking the question in the Fortran Forum or C++ Forum on eng-tips. Also, try googling the error.
Good luck
MRG
I was wondering if you got anywhere with your link error.  I'm getting the same thing.
actually I did. I am using the Intel FOrtran 9.0 with Visual c++ 6.0 and ABAQUS 6.4-1. I had to install a different version of VC++as the other one was corrupt and it didn't give this error but it still gave some other error. I asked the ABAQUS helpdesk . They sent me a workaround for Intel 8 compiler and VC++.NET and ABAQUS 6.5. That worked for me as well. You need  to make changes in .env file.
good luck!
