SECTION VIII - DIV 2
WHAT IS THE DIFFERENCE IN THE PROCESS OF MODIFICATION OF AN EXISTING NOZZLE ON A ASME SECTION VIII DIV 1 AGAINST DIV 2 VESSEL?
WHAT IS THE DIFFERENCE IF YOU ARE REPLACING AN EXISTING NOZZLE WITH A NEW NOZZLE.
PLEASE PROVIDE REFERENCES.
CAN YOU WELD TO A DIV 2 VESSEL IN MODIFICATION WORK? WHERE CAN I READ ALL THE RULES?
RE: SECTION VIII - DIV 2
One question - this is for an in-service vessel or new construction???
Try the NBIC, if you are in North America.  I suspect that you would also have to re-issue the UDS for a Div. 2 vessel.  However, the process likely varies from jurisdiction to jurisdiction.  Contact your local Boilers Branch (or Boiler Safety Association, etc) for specifics.
This is for an in-service vessel. We need to make the modification for installation of a new internal device for liquid/gas sepearation. The nozzle needs an internal flange for installation. Unfortunately the existing inlet nozzle does not have an internal projection and flange. Thus we might have to install a new nozzle with the internal flange.
The NBIC (National Board Inspection Code) is the reference document that should be used if this is an in-service vessel, and I would suggest you obtain and review this information. This is also an international standard. There are very specific requirements for Div 2 vessel modifications/alterations. The most important is having a registered PE review and approve the design calculations for this activity.
