standards' revisions
I'm looking for a standard drafting note to apply to our drawings that removes the need to write an ECO when the gov agency rev's the standard. I have looked through the Drawings Rq'mnt Manual however more input would be appreciated.
Example: MIL-STD xxx instead of MIL-STD-xxxA
Some note such as "all standards on drawing are revision verified prior to use" etc.
sds
sds
RE: standards' revisions
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
It is entirely possible that a revision will alter some aspect of the standard that was important to you, making "latest revision" unsuitable for your purposes.
When you reference a standard it is your responsibility to:
a: Find out what the latest revision is at the time.
b: Actually read and understand it before referencing it.
c: Ensure that you are notified of revisions, and read and understand what has changed in the latest revision. Then determine if the "latest revision" is still suitable for you.
On projects lasting many years it is common for references without revision to be "the latest revision in effect at the date of notice to proceed." This prevents a moving target over time.
(sorry about all the sort words... it's late).
Wes C.
There are no engineers in the hottest parts of hell, because the existence of a 'hottest part' implies a temperature difference, and any marginally competent engineer would immediately use this to run a heat engine and make some other part of hell comfortably cool. This is obviously impossible.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
However, if you specify an anodic coating to aluminum alloy per MIL-A-8625 you usually have to specify the type and class of the coating to differentiate between chromic to sulphuric or hard anodize. Added to this you have to specify the class which differentiate between the sealing and dying options. Then you must specify the revision.
Newer version may change the type and class designation (as already happened before) but always give a conversion table from the old types and classes to the newer one.
