Library feature configurations within a DT
Is it possible in SW2006 to control which configuration of a Library feature is used with a design table? I have several different configurations in a model and I would like to have a design table call a different configuration of a library feature that is used.
mncad
mncad
RE: Library feature configurations within a DT
If I get more time to play with this I will, because I would think the data is there and SW should be able to pull the Config parameters.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I'm working with a part, not an assembly. Its not a library part I want to control, but a library feature. SW2005 and SW2006 both support configurations of library features, after inserting a library feature in a part you can change which config is used. I would like to be able to change the configuration of the library feature for the different configurations of the part using a DT.
mncad
