Grinding Problems After Shutdown
We run production parts on a Blohm Grinder with tolerances usually around + or - .001. After a shut down of 48 hours over the weekend, the first part off the grinder is usually scrap. It is usually .002 or .003 under tolerance. Anyone have any ideas of what is happening? Wheel balance? We have started changing offsets on the first part and then working it back in tolerance, but this wastes time. We run the grinders three shifts 5 days a week and shut down over the weekend. We don't want to keep grinders on over the weekend. Anyone have similar problem? Any solutions?
RE: Grinding Problems After Shutdown
In order to hold close tolerances like these, the ideal situation is to have your machine as close to a steady state condition as possible in order to diminish or eliminate frame growth. All those hydraulics and electric motors heat the frame up and cause it to expand. It sounds like your machine is growing as it warms up and causing your parts to go undersize.
If the machine historically cuts undersize after a long shutdown, couldn't you just back it off a few thousandths for the first several pieces and creep up on your numbers??
Star for you, I was thinking along the same lines.
Can't add anymore to what you said, it covers the same things I would try.
Alan M. Etzkorn
Reliability Engineer
Wabash National Corp.
www.wabashnational.com
Barry1961
If you have known defects available, you should just run a piece of known scrap as the first piece to get the machine up to temperature instead of making a piece of scrap with the first piece.
Short of that, reset the machine for the first piece, then adjust to compensate for the temperature change.
rmw
If using a mag chuck put a 0.0025 inch shim under the part the rest of the week.
Schedule that grinder for 1 hour less/week. 119 instead of in 120 = 0.8% less production.
Stagger that person's (or 2 people's) shift. (~ free ?)
Forward ( to get machine warming up
Buy some heat blankets and maybe a timer ? ( $ 100s )
Leave the coolant on all weekend, with a heat blanket on the sump.
