help with printing in VB .net
hi need some help
i'm new to vb .net and want to print from a form but cant seem to get the print dialog to display. i can get the print preview up but wont put an image in it,
thanks for any help with this guys
RE: help with printing in VB .net
You may get better results by posting this at tek-tips.com
Sorry to bring bad news, but we struggled with printing from vb.net also.  There are utilities availble out there to help (so I am told), but when I contacted a colleague w/ a lot of VB experience, he said "It's not what VB is for.  Get the data out to another program, which VB is good at doing, and print it from there."
Some manage to print from VB, but I've seen it and would rather take the easy way and transfer data to a print- friendly app.
Good Luck!
Hi Leetech,
If you are wanting to print the form, this is the method I use.  For the form, Met3Grid, the code for the Print Form Button (Command4) is as shown below.  Most of this code simply turns off stuff not to be printed and then after printing, turning the stuff back on.
Private Sub Command4_Click(ByVal eventSender As System.Object, ByVal eventArgs As System.EventArgs) Handles Command4.Click
        Dim J As Integer
        Command1.Visible = False
        Command2.Visible = False
        Command3.Visible = False
        Command4.Visible = False
        Command5.Visible = False
        Command6.Visible = False
        Label5.Visible = False
        Label6.Visible = False
        Label7.Visible = False
        Label8.Visible = False
        Met3Grid.DefInstance.BackColor = System.Drawing.ColorTranslator.FromOle(&HFFFFFF)
        'We make the form look pretty before its picture
        Application.DoEvents()
        Me.Refresh()
        'Get a Graphics Object from the form
        Dim FormG As Graphics = Me.CreateGraphics
        'Create a bitmap from that graphics
        Dim i As New Bitmap(Me.Width, Me.Height, FormG)
        'Create a Graphics object in memory from that bitmap
        Dim memG As Graphics = Graphics.FromImage(i)
        'get the IntPtr's of the graphics
        Dim HDC1 As IntPtr = FormG.GetHdc
        Dim HDC2 As IntPtr = memG.GetHdc
        'get the picture
        BitBlt(HDC2, 0, 0, Me.ClientRectangle.Width, Me.ClientRectangle.Height, HDC1, 0, 0, 13369376)
        'Clone the bitmap so we can dispose this one
        Me.Print_Image = i.Clone()
        'Clean Up
        FormG.ReleaseHdc(HDC1)
        memG.ReleaseHdc(HDC2)
        FormG.Dispose()
        memG.Dispose()
        i.Dispose()
        'Show the PrintDialog
        PrintDialog1 = New PrintDialog
        PrintDialog1.Document = PrintDocument1
        Dim r As DialogResult = PrintDialog1.ShowDialog
        If r = DialogResult.OK Then
            'Print the document
            PrintDocument1.Print()
        End If
        Met3Grid.DefInstance.BackColor = System.Drawing.ColorTranslator.FromOle(&H8000000F)
        Command1.Visible = True
        Command2.Visible = True
        Command3.Visible = True
        Command4.Visible = True
        Command5.Visible = True
        Command6.Visible = True
        Label5.Visible = True
        Label6.Visible = True
        Label7.Visible = True
        Label8.Visible = True
    End Sub
