Conversion of BTUH to ton of refrigeration
I am looking for the conversion factor to convert the BTUH into TON OF REFRIGERATION. And how could I measure the available cooling load capacity given that I had a 2 air cooled chiller with a 4 chiller compressor.Capacity of Chiller: 370 TOR each. The facility equipment we had in the factory are follows:
1. 4 air washer unit
2. 5 air handling unit
3. Cooling tunnel
4. 2 units of dehumidifier
3. Cooling tunnel
RE: Conversion of BTUH to ton of refrigeration
Alternately, you can approximately check this if you know the mass flowrate of refrigerant, the suction condition of refrigerant and the liquid parameters. Chiller manufacturers generally perform these calculations. I suggest Principles of Refrigeration and Air Conditioning by Roy J Dossat, an excellent reference for your life time.
