Exporting DXF's
Exporting DXF's
Exporting DXF's
Is anyone having trouble exporting drawing files to DXF. We have some multi page drawings to export. It seems to export about 2/3 of the views just fine, but several it just wont do it.... (2006 btw - first series of exports on the new release)
Wes C.
There are no engineers in the hottest parts of hell, because the existence of a 'hottest part' implies a temperature difference, and any marginally competent engineer would immediately use this to run a heat engine and make some other part of hell comfortably cool.  This is obviously impossible.
RE: Exporting DXF's
Are you using the Task Scheduler to export all the sheets sequentially? Does it just stop?
Using SW06, can you do a save-as to dxf, the problem sheets individually?
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions  FAQ559-1091
RE: Exporting DXF's
Hey Cory,
It's when we Save the sheets individually that the problem occurs. I havn't tried the task scheduler yet...
Wes C.
RE: Exporting DXF's
I doubt the Task Scheduler will help ... but it won't hurt to try.
Can you save-as any other format?
RE: Exporting DXF's
Try switching from "High Quality" to "Draft Quality", then save as DXF.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
