Spacing and Edge Distance in L-shaped Anchor Bolt
I have two L-Shaped anchor bolts that will be cast in place into a concrete block. I am trying to figure out where to find info on minimum spacing and edge distance (the manufacturer does not provide for these bolts.) The bolts are 1 1/4". Embedment length is 18", thread distance is 6" and the length of the leg in the 90 degree bend is 6 inches. I would appreciate any point in the right direction. Thanks..
RE: Spacing and Edge Distance in L-shaped Anchor Bolt
