Mobilisation of soil
Soil at rest has a lateral factor of k(o) associated with it.  How much movement (or soil strain) of a retaining wall is required to change the factor to k(a), assuming that the soil is granular.  Or are there other factors to take into account?
RE: Mobilisation of soil
Check out elementary soil mechanic books - they have a graph, usually, showing the deflection/height required to cause "movement" in the k values.  Sorry, but my books are packed away as I'm moving.
sloany,
See the NAVFAC books - I believe DM 7.2 has guidance on retaining wall displacements to mobilize active earth pressures.
Jeff
Jeffrey T. Donville, PE
TTL Associates, Inc.
www.ttlassoc.com
