Solidworks 2006 wont stop crashing....
I have recently installed solidworks 2006 and it wont stop crashing indiscriminately. It will crash during an assembly, when creating a feature, or during the drafting mode as well. I cannot see a pattern here myself. This was a fresh install, and all updates were performed prior to installation. Just recently I fully uninstalled the video driver and re-installed the reccomended one from solidworks. I have lowered the hardware acceleration, and disabled write combining on the video card settings. I have also done what this thread (thread559-135741) had suggested and it still keeps crashing. I don't understand why. Could I have some incorrect system settings? Or could my hardware not be functioning correctly? I noticed that when I downloaded the driver for my vid. card it was not certified by WinXP. I also get a fragment from my cursor when I click on the workspace or features...just a little square the size of the cursor display. If anyone knows what could be wrong I would really appreciate the help...this is begining to get very innefficient.
Thanks!!
Thanks!!
RE: Solidworks 2006 wont stop crashing....
-not installed correctly
-virus software is running when SW is installed
-incorrect hardware
-very little RAM
-no SW training
-problems with server and/or network
SP's will fix bugs and do updates, but these bugs are not usually culprits of crashes.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP3.1 / PDMWorks 05
ctopher's home site (updated 06-21-05)
FAQ559-1100
FAQ559-716
Could you give us a run down of your system (video card, driver, ram and OS)
Netshop21 - I would like to disagree with your statement
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Just because I'm paranoid doesn't mean that they aren't out to get me.
- Woody Allen
Your hardware specs would help greatly, but I will say that 2006 is more of a memory and/or cpu hog than 2005. At home I have a standard Dell desktop PC, and I can run 40 meg files in SW 2005 without any problem, but the same files in 2006 bogs my pc down.
Flores
SW 2005 SP 4.
Jason Forward
Solidworks 2005 sp3.0
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Video: ATI Fire GL X2 256t Driver 6.14.10.6521 (SW Reccomended)
Ram: 1 GB RAM non ecc
cpu: P4 3.0 GHz Hyper Threading
OS: Win XP Home
HD: 60 GB IDE Barracuda
Mobo: P4SD-LA ASUS board w AGP x8
Is this ok?
thanks!
2) XP home is not supported for SW06. It's not say it will not work, but it is not supported and I have had many people call with not being able to install on XP home or get a good install of it on their system... not honestly sure why that is, but it's not supported either.
3) Turn Hyper threading off - It's just a performance hit you probably don't want to take - See bios to shutoff
Please check out the Maintainence FAQ's as you need to perform these routines weekly. Defragging believe it or not helps out tremendously.
FAQ559-884
FAQ559-908
FAQ559-507
FAQ559-1066
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Alan M. Etzkorn
Reliability Engineer
Wabash National Corp.
www.wabashnational.com
Thanks for the information, I will give these a try and let everone know if the problem gets resolved. I am sure the video driver is fine, it was completely uninstalled and reinstalled properly. As for the Hyperthreading issue, I was unaware, I'll change it. One more question. How much would ECC ram help? Ive read its supposed to be more stable than non ECC...
Thanks for the help!!
Did the fixes suggested above help? or Not?
I'm concerned about 1 GB Ram, that's our standard setup here.
Not sure why XP Home won't work well, only diff are supposted to be networking ability.
Many thanks,
Wayne Walker
IS Dept, General Atomics
support69
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
