Wire rope clamping
Wire rope clamping
Hello all,
I need to verify the use of a 1/8" wire rope used to pull a load. I have the strength of the rope now the question comes up about the clamps. I am using the recommendation from the McMaster-Carr catalog as far as installation, is there another source i.e. industry standard that gives the number of clamps, location and torque? Thanks in advance.
Dennis
Dennis
SolidWorks 2006 SP0
Windows XP Pro, Pentium4 3.00GHz
1.5 GB RAM, Matrox P650
Logitech Marble Mouse, CADMAN
RE: Wire rope clamping
Check the Crosby catalogue (Wire Rope End Fittings - Application Information) for a cross-reference at...
h
Cheers,
CanuckMiner
If you are going to use Bulldog clamps, the rule of thumb is "never saddle a dead horse". This means that the saddle of the bulldog clamp should not be on the end of the loop if you make loop in the wire rope.
Tofflemire
Dennis
SolidWorks 2006 SP0
